  • Chris 49 posts 67 karma points
    Mar 17, 2011 @ 16:03
    Chris
    Cannot have ']]>' inside an XML CDATA block.
    What would cause this? Using 4.5.x......
    Mar 17, 2011 @ 16:07
    Kim Andersen
    Are you trying to insert some special code (eg. something with ]]> in it) into the richtext editor? If that's the case, the error occours because the html from the richtext editor are stores as XML inside CDATA
    Could you maybe provde us with a little more details?
    /Kim A
    Mar 17, 2011 @ 16:14
    Chris
    Hi, Kim:
    Thank you so much for replying so quickly.  What I have done (I know it is not the most efficient way) is use AJAX Controls for a Content Panel Extender; about 14 fields.  I am then using richtext editor fields to sub data into each title and content fields so it can easily be edited (still new to umbraco and xlst).  I was able to enter a few but now getting the error.
    I am only entering html code into the richtext editor fields (entering html code into the html section - not rich text section) and I am not using "]]>" or anything like that.
    Mar 17, 2011 @ 16:20
    Chris
    Ahhh. Kim you saved me.  I had entered javascript in the rich text editor
    <span style="text-decoration:underline;"> <script type="text/javascript">   document.write(userName[0])</script></span>
    to hide an email address and that is what threw it.
    Best solution is to use this field without the richtext editor?
    Mar 17, 2011 @ 16:31
    Kim Andersen
    If you want to insert some javascript from the Umbraco backoffice I'd suggest that you put it in a textbox multiple. In this data type you can insert all kinds of code without breaking anything. And it's rendered fine on the frontend.
    /Kim A
    Mar 17, 2011 @ 17:15
    Chris
    Thanks, Kim.  Really appreciate the help.
    Chris.
    Mar 18, 2011 @ 08:23
    Kim Andersen
    You are very Welcome Chris. Glad the suggestion works for you :)
    /Kim A
  • Maurice Melchers 4 posts 24 karma points
    May 29, 2012 @ 00:24
    Maurice Melchers
    Hate casting lvl 5 resurection on old treads. But I'm having this problem with a textbox multiple datatype.
    I'm trying to add tracking code which contains this code in this textbox and it gives me this error. Using umbraco v 4.7.1 (Assembly version: 1.0.4281.20201)
    M
    May 29, 2012 @ 01:03
    Maurice Melchers
    to elaborate, here's an example of the conversion code: http://support.google.com/adwords/bin/answer.py?hl=en&answer=1722021
    I just want people to copy paste it into any textbox, and this giving me errors.
